2000 Ford Tractor
1SG Steve
Well what can I say except thanks for all the advise and expertise. Tractor is purrrrring like a kitten and used some Bars block sealer and no leaks. I just finished bush hogging a small section that took about 45 minutes and all is well. Thanks again and will catch you all later..
Seen several ruined by using snake oil stop leaks. Expect your cooling system to give you big troubles in the future. Tom
Sounds like you did good. I've always had good results with Barrs though I never tried it for a block leak. When I got my Dakota many years ago I noticed it had what looked like a little Barrs under the radiator cap. Dealer told me that put it in all of them brand new. Wish it would seal up in my 7610 but I think the hole in it is a little big for that.
