i am an experianced machanic and i run a business repairing tractors and selling parts, so i am a little embarassed to ask this. i am in the middle of an engine OH and replacing the clutch and input shaft seals. when i drove the trans input seal into the pto shaft, it fell into the bore, i pulled the seal back out(with my fingers) and measured the bore and the seal, they are the same. the bore is 1.507 and according to the seal manufacture it should be 1.499. i have done this job serveral times before and everything was ok. i got a new national seal and had the same problem, the original seal came from CNH and was a CR seal. has anyone ran into this before? i know that it will not seal and i will probably open the ID of the pto shaft up to the next seal size, 1.512. just wanted to know if anyone has seen this or if i just have a mis-made shaft. the strange thing is the old seal pulled out good with enough press. i'm stumped.
