Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3000 Parts Online
Ford 3000 manifold heater
PaulH in Ontario
12-09-2008 14:52:48
How does the manifold heater on a 3000 diesel work and the proper operating proceedure can"t seem to find in manual Thanks Paul
Brian Allen
12-10-2008 05:48:36
 Re: Ford 3000 manifold heater in reply to PaulH in Ontario, 12-09-2008 14:52:48
PaulH in Ontario
Its on page 14 & 15 in your operators manual.
The ignition switch should be put on heat for 30 seconds (Or hold the button in) which turns on the manifold heating element and allows the fuel to access the element and ignite.
This preheat the intake manifold and provides hot air to the engine making it easier to start.
Tractors with the Simms injection pump have a button that can be pushed in to provide extra fuel for cold starting.
Operator and repair manuals are very important to the operation and maintenance of your tractor, you won't ever regret their purchase.
Brian
Welding man
12-09-2008 15:17:52
Ford used a thermostart system. Fuel was stored in a little tank and that was filled by the return line from the injectors. A heating element in the thermostart allowed a bimetalic valve to open and fuel hitting the element vaporized into the intake. I have seen them actually catch on fire if you remove the intake hose where it can get enough air. If your 3000 still has the original Ign switch you have to turn it to the left an hold it a few seconds, just to the point before the starter engages. If the switch has been changed to the new style, your thermostart should work every time you start it.
Ultradog MN
12-09-2008 19:59:30
 Re: Ford 3000 manifold heater in reply to Welding man, 12-09-2008 15:17:52
My 3600 has the thermostart but all that stuff - tank, tees, hoses etc were all burned away in the fire. I have an extra glow plug and the little, pot metal reservoir/tank off a 3400. Haven't deciphered everything I need to make it work.
What triggers the fuel to bleed from the tank down into the glow plug?
Fordfarmer
12-10-2008 06:55:41
 Re: Ford 3000 manifold heater in reply to Ultradog MN, 12-09-2008 19:59:30
The system on the x600 series isn't quite the same as the older ones, although you could probably swap parts around and make them work. The newer systems do away with the reservoir and some of the lines - as far as I know, they just use a line T'ed from the bleed off lines to the heater.
Welding man
12-10-2008 05:59:59
Please read my post above a little closer, the heat from the heating element opens a little bi-metalic valve. Sometimes they will fail open. dumps diesel fuel into the intake all the time, makes the tractor smoke like the dickens.
RickB
12-09-2008 15:34:55
Current style Ford Ignition switches for 3 cylinder (and most 4cyl) have a preheat only position between 'ON' and 'crank". Just when the idiot lights go out, that's preheat. They do also preheat while cranking.
RickB
12-09-2008 15:34:01
RickB
12-09-2008 15:33:45
Copyright © 1997-2015 Yesterday's Tractor Co.
