for those of you that have been following the saga of my new / used 3000 tractor with starting problems:
http://ytforums.ytmag.com/viewtopic.php?t=382908&highlight=
http://ytforums.ytmag.com/viewtopic.php?t=391076&highlight=
Here is what I found wrong:
1. battery is a 500 amp from a Honda Civic or something?
2. Cables are aftermarket parts store type.
3. themostat was failed open and engine never came to operating temperature.
4. Injector was failed: fuel in oil, slobbering all over me!
5. generator not charging
Here is what I have done so far:
1. Have not changed battery yet. I pulled one of the 900 amps out of my Dodge CTD and it was no different with starting. Will change in the future when my tractor jar gets a little more jingle in it.
2. will replace cables same time I do battery.
3. replaced thermostat and now the engine comes to temperature normally.
4. replaced all three injectors with exchange set.
5. replaced generator with 1-wire alternator.
Results:
I found the compression low on one cylinder but I have not done anything as it could be related to fuel glazing down the cylinder walls and low spin up speed due to a poor battery and cables. I am going to run it hard and see if it comes up first. I will not be able to do this untill next year when I start mowing the deer hunting land. Untill then it will just be used to move trailers around....
The fuel in the oil and slobbering is gone. Oil is nice and clean after running and sitting. (this one worried me, but all is well now).
It is still hard to start when cold but will start with ether and will start on its own afterward for the day. Doesnt smoke as much and runs really good. This may clear up after I run it in to get the compression up and change the battery and cables.
So, as of right now I am really happy with the results.
Thanks again for all of y'alls help.
Results:
