Ok as posted earlier, tractor is hard to start but runs fine when its going without too much smoke. Here is what I have found related to the fuel system:
1. getting a little fuel in the oil. Not while sitting, only while running.
2. I did find the thermostat was failed open and the engine never came to operating temperature. I changed the thermostat and now it warms up normally.
I am not sure how much fuel is in the oil as I just bought it and was not sure it was right to start with so I drained and refuilled with new oil. I put in about 6 quarts and have been watching it without starting it. I am going to start it up and run it hard and see if the level comes up and go from there.
here are my questions:
I believe based on what I have read that the hard starting and fuel in the oil is injector related. What would be the cheapest way to go (yes I am cheap). I was thinking of using Seafoam in the fuel to see if the injectors will clean out on there own. If not, I was going to send them to a shop to get them serviced. Is this a good plan? Is Seafoam ok to run in these engines. I know I could take the injection pump off also but I really dont want to spend the money unless I have to.
What are your thoughts?
