As post states, right brake locks up when engaged and will not unlock unless I take a hammer to the linkage to free it.
Are there any common problems that can cause this or do I need to start tearing it apart to troubleshoot?
I looked at the shoes and they have about 1/16" remaining. Not new but enough to last a while I think. If they are worn too much can that cause this?
The tractor was recently painted before I purchased it and I am wondering if the rod going thru the differential is all painted up causing it to stick? Or, maybe it is bent? I lubed up everything and it is to no avail. At any rate, I have been using the left only for stopping at this time and would like to know any thoughts you all may have.
Thanks in advance for all of your help
