lonestarjeff
Pulled all the front-end stuff off the 860 this last weekend to start prepping for paint. I noticed the governor arm/shaft is kinda loosey-goosey in the housing. There's some in/out movement(I think the seal is gone) & it moves very freely fore & aft(which I suspect is ok)............
<a href="http://s11.photobucket.com/albums/a167/lonestarjeff/?action=view¤t=DSCF1751.jpg" target="_blank">
</a>
There was quite a bit of fresh oil around the front cover before I cleaned most of it off, but no way to tell how much was from the shaft seal. Also, it had a long-term leak coming down from the valve cover which may be the majority of it.
I don't know if this is the early(ball-type)governor or the later one, but either way I guess it'll have to come off to replace the seal. If I can find one, I'll probably install a double pulley in place of the old single...maybe add power steering at some point.
BTW, do the 800's tend to run hot? This one had no t-stat installed.
Jeff
Jeff
