1958ford641
New User
I was Bush hogging and the tractor started to vibrate so I stopped, disengaged the PTO and lifted the cutter, found nothing on the cutter, went to engage the PTO and it would not engage. I noticed when I tried to engage the PTO the output shaft would poke out and I heard a grinding from the tranny. I tried to engage it with the motor running and with itoff, I could pull the PTO shaft, engage the lever and stick the shaft back in and it would stay engaged(with no vibration) Once I dissengage it again it would not engage again and would grind. I removed the rearend of the tractor hoping to find something obvious, but all looks well shafts are straight and splines are clean and straight. I did notice after removing the coupling sleeve that the front shaft in the tranny has about 1/2 inch play in/out. Is that normal? I would rather not remove the tranny also. Any Ideas?
Thanks,
Mark
Thanks,
Mark
