Anonymous-0
problem with flow between hydraulic tank and transmission, transmission will overflow with fluid, hydraulic tank will drain down. Previously was having an issue with transmission running toward dry with no flow coming in. Fluid was going to hydraulic tank but not to the transmission. Ran external pump from hydraulic tank to transmission to keep fluid from running out in trany. Now the problem has flipped with too much in the trany and the hydraulic tank running dry which is effecting other circuits.
