'64 4000 power steering gear
Larry NCKS
I was mowing the lawn w/my 4cyl 4000 when oil started running out the right steering shaft seal. New Holland's website does not list a seal kit or overhaul kit for this steering gear that I can see. Does anyone know of a good aftermarket source for such a thing? Thanks!
Just curious, how can I tell if my 4000 (4cyl) has power steering? I didn't even know the 4 cyl models had that as an option.
Larry;
Try external_link or nnalert, they both list the seals. The seal I believe you are talking about is CNH # D5UZ3591A and was used from 1953 up. (According to the CNH site) Doing a quick search, it's the same number for the 800 series.
3 things. Power steering pump on the right side of the engine, hydraulic cylinder on each side and hoses.
