Dan Francis
New User
I have a DBGVCC 429 4AL on my 63 or 64 Ford 4000. I think the govenor ring is going out. It will surge to high RPM's and the throttle will not respond well at all. Just a slight tap down it will die, slight tap up it will rev up too high. Will a leak in the fuel return line cause this? Does anyone know if a DBGVCC 435 16AP pump will work in place of this one. I do know the plunger size is bigger but what other differences are there. I recently cleaned the fuel tank, changed the filter so I am dealing with good fuel delivery. It's wierd though, one day I can start it up and it runs great just like it should and another time start it up and it wants to run crazy. Will the govenor ring cause that?
Thanks
Dan
Thanks
Dan
