Order Ford 600 Parts Online
1977 Ford 1600
rpeak
03-31-2008 17:39:51
Just found a 1977 Ford 1600. $3500 for tractor, finish mower, scraper blade, and old disk. Tractor has 2200 hours on it. Anyone give me any info on this tractor and if it may be worth it. Picture appears that tractor is in fair cosmetic shape also.
RodInNS
03-31-2008 20:22:12
 Re: 1977 Ford 1600 in reply to rpeak, 03-31-2008 17:39:51
Those tractors are getting hard to get parts for. NH has been organizing parts obsolence for some time and they were never built in such numbers as to support widespread aftermarket support. Common reman stuff like clutches, injectors and such would be available but I wouldnt' want to get into an engine.... What is available is astronomical.
I'd want to negociate the price such that if i had to walk away from it tomorrow or part it out that I wouldn't be behind, or at least not behind by an amount that I couldn't afford to lose...
I think the price could come down some without knowing anything about the condition of the impliments.
Rod
soundguy
03-31-2008 18:20:22
Here's some basic info.
soundguy
Drawbar (rated): 18 hp [13.4 kW] Drawbar (max): 18.1 hp [13.5 kW] PTO (rated): 23 hp [17.2 kW] Engine Manufacturer: Shibaura Fuel: diesel Cylinders: 2 Bore/Stroke: 3.54x3.94 inches [90 x 100 mm] Displacement: 77.6 ci [1.3 L] Rated RPMs: 2500 Cooling: liquid
