Ford 705 snow/dozer blade
Brian in MI
01-02-2008 21:27:46
Does any one have one they want to sell? I'am looking for a ford 705 front mount dozer blade. The only one I have been able to find is $300 and has the sub-frame on the tractor and snow blade for a thousand series, but the a-frame from the blade to sub-frame for a hundred series. no cylinders either. won't budge on price either. Does any body have pics and dimentions for the a-frame I would need to fabricate?
Thank you in advance,
Brian
Brian in MI
01-07-2008 17:59:45
 Re: Ford 705 snow/dozer blade in reply to Brian in MI, 01-02-2008 21:27:46
Mike,
I would appreciate any photos you have, I just picked up a 705 snow blade today. It has the subframe, a-frame and blade all in good shape. Also has the lift cylinder. I need to run lines for the lift cyl, and I'am going to try to make it hyd turn also. The only issue I see is I may have to beef up the a-frame for the hyd turn cylinders.
thank you,
Brian
Michael Williams
01-08-2008 11:17:55
 Re: Ford 705 snow/dozer blade in reply to Brian in MI, 01-07-2008 17:59:45
Send me your Email address to Kawasaki6r@aol.com and I'll take some pictures of my Ford 3000 tonight - I have the blade on..
Michael Williams
01-07-2008 12:44:54
I just rebuilt the same plow (paint, lines, etc, etc)
Let me know if you need any specs, pics, etc..
Thanks.. Mike
steve n carol
01-04-2008 18:30:41
 Re: Ford 705 snow/dozer blade in reply to Mashbox, 01-02-2008 21:27:46
Brian, you might try looking in the photo galleries to the left. Search for snpw plows. I was looking for ideas (for fabrication) and saw plenty...sl
Brian in MI
01-04-2008 10:31:38
That is the dozeer blade with the solid mount. That would work, the snow blade had the spring mount and the blade had little flares on the sides. Over all they are pretty much the same. Thank you for the info wish I would have seen it before the auction ended.
Thanks again,
Brian
Mathias NY
01-04-2008 15:51:09
 Re: Ford 705 snow/dozer blade in reply to Brian in MI, 01-04-2008 10:31:38
I guess I should have asked, do you still need pictures or dimensions? I have the part that mounts on the tractor and the a-frame that attaches to it.
Mathias NY
01-04-2008 08:13:50
I'm not sure if this is the blade you are looking for. It was an ebay auction with some decent pictures of a factory dozer blade for on a 3000.
I have everything except the blade and the cylinder for my 3000. I also have a 7.5' Fisher plow with twisted A-frame that I hope to adapt onto it. With any luck I will get to that project yet this Winter...
