Uh.. no.. ford never mae a 1.72 volt model... only 6v and 12v (wink). That machine should have a B-Circuit lucas 12v genny and regulator. Have you polarized it? Take a jumper wire and jumper from battery 'hot' to the field post on the genny. Then start her up and get her to 900 rpms or soo and see if your gen lamp doesn't go out. If it is still on, jumper the post again while it is running. If that makes the lamp go out.. but it comes on when you remove the jumper, then the reg field circuit is bad.. replace the reg. If lamp don't go out, then it's time to decide if it is the genny or the regulator cutout. Turn engine off, slip belt off genny, jumper battery HOT to genny armature. jumper field to bat hot/armature. gen should spin ( motor ). Most gennies that motor will charge.. most gennies that will charge will motor. If the gen motors, but when you hook her back up charge voltage does not come up on the battery, and lamp doesn't go out, then bypass the reg altogether.. start tractor, set to 1000 rpm, jumper bat hot to field.. then jumper bat to armature.. if charge voltage comes up on the bat, then you have a bad vreg cutout and/ or field and cutout. replace the reg. If the genny don't motor.. then take both to a rebuilder.. the genny needs attention and you can't easilly check the vreg without a working genny. ( Actually you can.. using a spare battery and a battery charger.. but it gets involved for the non electrically inclined ). post back if you need help... these charge systems are super easy. Lucas gennies are fairly tough.. though not so much as a ford genny.. however the lucas regs are fairly junky.. some of them can be revived by a contact cleaning.. but you are living on borrowed time.. etc. If you are industrious, you can swap in a 12v reg from a ford 100 series diesel in place of the flaky lucas reg.. it is much more robust.. however.. it is only charge limited at 25a or so.. where the lucas reg is charge limited to 20a so theoretically you can overwork the lucas genny with an older ford reg if you have an amperage demand in excess of 20a.. etc... Soundguy
