Order Ford 3000 Parts Online
Ford 3000 Draft Control
Jim Latch
05-14-2006 16:10:07
Sorry, I used the wrong email address the first time
I am using a turn buckle to keep the draft control lever all the way down, if the lever is in any other position the bush hog will go all the way down. I am by-passing the system by taking the third member off and using the rear wheel of the bush hog. If I leave the third member on the bush hog wants to come all the way up every time the back wheel hits the ground. Any suggestions would be appreciated.
BobReeves
05-14-2006 16:49:57
 Re: Ford 3000 Draft Control in reply to Jim Latch, 05-14-2006 16:10:07
On my 3000 the lever has to be up for position control. Down (in Draft) will do what you are describing. Move it up and see what happens.
It should raise or lower the 3 point arms somewhat leiner with the handle and stay there as long as the tractor is running. If your 3000 isn"t doing this something is wrong..
Jim Latch
05-14-2006 17:06:12
 Re: Ford 3000 Draft Control in reply to BobReeves, 05-14-2006 16:49:57
Thanks Bob. If I position the lever anywhere else the bush hog or any other tool will not go up
RodInNS
05-14-2006 19:06:55
 Re: Ford 3000 Draft Control in reply to Jim Latch, 05-14-2006 17:06:12
Sounds like it's time to do an internal linkage overhaul on the tractor. There's probably a worn cam follower, along with some sloppy linkage, and that's why the position control isn't working. Remove the lift cover and inspect what's worn, and also reseal the lift cylinder if it's been bypassing or dropping quickly. If you are going to do this yourself, then it would be an immense help to have a Ford service manual as opposed to an I&T manual. The Ford book will give a good description and operation section to give you a good understanding of the system, and probably the specific measurements for setting the linkage without using special tools. Good luck.
Rod
Jim Latch
05-15-2006 19:32:58
 Re: Ford 3000 Draft Control in reply to RodInNS, 05-14-2006 19:06:55
Thanks Rod, I will give it a try.
phil lowe
05-17-2006 15:14:24
 Re: Ford 3000 Draft Control in reply to Jim Latch, 05-15-2006 19:32:58
and be cautious where you get your manual from.I got one that has terrible pictures and schematics in it.everything was a photocopy and some stuff is un readable,I won't mention which site I bought it off of,,you may be able to guess why ??
Jim Latch
05-17-2006 20:40:21
 Re: Ford 3000 Draft Control in reply to phil lowe, 05-17-2006 15:14:24
Thanks Phil, I'll be careful.
