Order Ford 800 Parts Online
Ford 8000 transmission
Russell Venier
11-21-2005 14:42:03
MY FORD 8000 HAS A PAUSE IN THE TRANSMISSION WHEN THE RPM'S GO INTO LIKE A FLOAT STAGE. ALSO, WHEN I HIT A DRAINAGE DITCH IN A FIELD IT COASTS INTO IT AND THEN HESITATES BEFORE IT JUMPS BACK AND STARTS TO GO AGAIN. ANY HELP WOULD GREATLY BE APPRECIATED.
Pernell
11-22-2005 12:45:57
 Re: Ford 8000 transmission in reply to Russell Venier, 11-21-2005 14:42:03
Sounds like you're loosing oil pressure to the Dual Power. I'd do a fluid pressure check.
Bob Reeves
11-22-2005 08:03:59
First, please turn your Caps Lock off, makes posts hard to read.
Can't answer your question but hope someone that knows the old Fords chimes in because my 3000 does what you are describing to some extent. Not enough to really concern me but your post aroused my curiosity.
