1980 Ford loiuisville clutch problem
Denis Hillaregu
10-27-2005 22:00:14
I put a new clutch and throwout bearing in the truck and adjusted it both ways and neither way got me the freeplay desired 1" to 2" I adjusted the linkage now there is no freeplay and it still won't go into gear? Any help would be welcome.
gerard
10-28-2005 15:19:55
 Re: 1980 Ford loiuisville clutch problem in reply to Denis Hillareguy, 10-27-2005 22:00:14
Did you put the driven plate in the correct way round?
RodinNS
10-28-2005 08:19:00
Are you adjusting actual linkage free travel, or are you adjusting the free travel through the adjustment ring on the pressure plate? If this is a "pull" type heavy clutch in front of a RoadRanger, you will have to adjust the ring. Clockwise to tighten, counter to loosen..... Now... if you didn't free that bugger up before you put everything back together..... . Many a clutch was allowed to expire because the adjustment ring was seized, and the only way out was to pull the tranny..... and well..... do a clutch job. Hope you're not going down this route.....
Rod
