#3 Band adjusting bolt froze fast
John
03-31-2003 17:30:02
I wanted to adjust the bands on my 1966 4000. #2 adj.bolt was tight, but it broke loose and was able to release pressure. I can't budge #3. Broke a screwdriver, tried turning a piece of flatstock in slot with a wrench, was afraid of breaking out slot on end of bolt. Anyone have this problem? Would a little heat on the bolt help? Thanks for your help. John
Texadian
04-02-2003 12:11:50
 Re: #3 Band adjusting bolt froze fast in reply to John, 03-31-2003 17:30:02
Are you adjusting bands two and three when they're released? They're applied with springs and band 3 has an especially strong spring. They must be adjusted with hydraulic oil pressure compressing the springs to release the bands.
Relying on memory now, I think you adjust band three with the engine running in neutral and the rear wheels disconnected (check the manual). With the lock nut backed off, turn the screw in till you feel resistance, then back it off three quarters of a turn. Shut off the engine, let the band apply, it'll hold the screw while you tighten the lock nut.
John
04-04-2003 13:50:16
 Re: Re: #3 Band adjusting bolt froze fast in reply to Texadian, 04-02-2003 12:11:50
You are right. I did not have the tractor running. Thanks for your help.
