Jerry, I now have a pretty good idea about what it is you're trying to do here. The first thing I want to say is this: do you realize how slow that loader will be running it off of the tractor hydraulics? According to my info, that pump puts out a whopping 4.3 GPM at rated engine speed (5.3 GPM for the piston pump on the 3 and 4000s). This I'm afraid to say is painfully slow. Even with the single lift cylinder on the one arm loader, I would think it has to be pretty good sized. You might wish to compute the volume area of the cylinder by measuring the bore size and stroke, and then figure your cycle times from there and ask yourself if that's really what you want. By comparison, most 2-5000s out there with a conventional 2 lift cylinder front loader are using front engine mount pumps putting out anywhere between 12 and 20 GPM. Another consideration would be a PTO pump of some sort. If you intend to use the tractor hydraulics and this plate for your power source, I have it figured out now. The "P" port is for pressure in to your loader control valve. A word about the loader control valve that you choose. It HAS TO BE open center WITH power beyond capability. This type of valve will also have 3 ports (in addition to the work ports): pressure, return, and power beyond. The PB port is a source of pressure oil tapped downstream of the loader valve circuit used to power the 3 point, via the adapter plate. Also, the loader valve does not need to have its own relief valve, as the tractor has its own relief. The exception would be if you don't want the loader to operate at 2500 PSI (the tractor relief setting). Think of the system as a series circuit. The oil goes from the pump straight to the adapter plate. From there it flows out of the "P" port and on to the inlet of your loader valve (this is why the "P" port can never be plugged, the system will then be constantly going over high pressure relief). If the loader is not in use, then pump oil flows out of the loader valve PB port and onto the PB port of the adapter plate. This oil then goes to the 3 point hitch circuit. Without this plumbing in place, the 3 point would not work, as it is the last function to receive oil. The return port on your loader valve only flows oil when you are actually moving the loader (return oil from the cylinders). This oil goes to the return port on your adapter plate and then straight to sump. This oil cannot be used to power the three point because the loader valve return oil gallery cannot stand the potential high pressure being generated by 3 point use. So then, at the risk of confusing you even more, I'll tell you how to plumb this thing: one hose from the "P" port of the adapter plate to the inlet of the loader valve. One hose from the PB port of the loader valve to the PB port of the adapter plate. One hose from the outlet (or return) port of the loader valve to the return port of the adpater plate. The first two hoses need to be rated for 2500 PSI minimum. The return hose can be lower. On your log splitter, you again have two choices: 1) plumb the two power hoses for the splitter control valve directly into the loader valve lift or dump circuit, using quick couplers. Doing this, you would have to hold the loader valve lever back while the log splitter is in use. You would also have to be careful not to reverse the flow. You could reduce the potential for problems here by running the return for the splitter straight to sump, rather than through the loader valve. 2) you could tap the pressure line for the splitter valve directly into the PB hose coming off the loader valve, again using quick couplers. The return would again have to be routed straight to sump. Both of the above options would be fine as long as you don't expect the 3 point to work while you are using the splitter (I'm not sure if the splitter is mounted on the 3 point or not). If you went with option #1, you could return the loader valve spool to neutral momentarily to make the 3 point active again (remember, the loader valve has priority to the oil over the 3 point). Another option would be to replace your log splitter valve with one similar as the loader valve, then route the oil as follows: pump>loader valve>splitter valve>3 point. This is not likely to be a viable option due to the added expense. Hope all this helps and that I didn't confuse you even more.
