Order Ford 3000 Parts Online
How do I check the hydraulic fluid on a Ford 3000
Rickey
03-19-2001 08:39:09
How do I check the fluid level on a Ford 3000 and is the same type fluid used in the hydraulics as the rear housing. It appears to me that they are all one unit. Is there a filter and if so where is it located and how often should it be changed. Thanks so very much.
Festus
03-19-2001 18:40:44
 Re: How do I check the hydraulic fluid on a Ford 3000 in reply to Rickey, 03-19-2001 08:39:09
There's a square-headed bolt just below the draft control lever on the right hand side. That's the level for the rear end and hydraulics. Hope this helps. Festus
