Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO 30 overheating fuel boiling
GranOlaFarms
09-14-2012 06:18:19
"The engine should be idling at 400rpm."To adjust timing:- turn distributor cam in normal direction as far as it will go,with distributor adjustment slack, then hold onto cam in this position, now turn the distributor in opposite direction until the points JUST start to open, and lock it up. Fit number one HT lead in the contact over the top of position of the Rotor arm when you have set timing" The ignition should be set with number one piston on compression at TDC, the flywheel set to 31 deg to the scribe line in the inspection hole, and the points should be just opening, when the distributor shaft is in this position. This is the correct timing procedure as in the manual, it may just help"....John
Is this the same for my TO 30 to set timing? or do I use a light and set it at 7 BTDC.. thats what I have in my notes here..
Thanks again I have a manual somewhere but in the process of moving and am not sure where
Jerry/MT
09-14-2012 20:02:01
 Re: TO 30 overheating fuel boiling in reply to GranOlaFarms, 09-14-2012 06:18:19
Use a timing light and set it to 7BTDC @ 400 engine idle rpm. Rev engine and observe timing advance. If it doen"t change, advance mechanism is stuck.
GranOlaFarms
09-16-2012 06:02:00
 Re: TO 30 overheating fuel boiling in reply to Jerry/MT, 09-14-2012 20:02:01
Thanks
still tinkering I think I have a Gremlin as it keeps changing its symptoms. Even if I have changed nothing myself so I shouldnt be creating my own tail to chase..
