| Harry Ferguson Tractors Discussion Forum |
Topic: Re: 1948 Ferguson TE-20 and Bush Hog Rotary Cutter 105
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| John(UK)
09-11-2012 06:37:55
79.76.242.19
Use Multi-grade 10W/30 oil, it is much better in cold weather and is a better for the hydraulics because it is thinner and has additives to prevent wear. Where-as the original type was just a plain oil and nothing in it. Having said that, although you can buy oil that is sold as the original oil, it now has additives but still gets thick when cold, so you are better using the Multi-Grade 10W/30 oil. The Bush-Hog, have you checked if the Bearings are worn in the Gearbox, if they are you need to change them and perhaps not cut as low as that is what causes them to wear, that and running without oil.If you did use grease in the gearbox you should also add some gear oil so that there are never any cavities in the grease which would mean that the parts are not getting proper lubrication, using some gear oil in with the grease would mean that the oil would run into these cavities. But check the Bearings and sort them out if necessary, even the grease Will run out if it gets hot, so you will never completely cure it if the bearings are worn. Just grasp the Blade under the Deck to see if there is any up and down movement at the tip of the blade, if there is the bearings are worn. Never set the Hog so low that the blades touch the ground, even if it is only occasionally, it is a mower not a Rotovator and it isn't made to do that. Set the back 2" higher than the front this will allow the cut grass etc. to escape more quickly and not use as much power, set the front high enough to keep out of the wet stuff in the bottom. If you would like more information about your tractor and using it with a Hog, Email me at the address below and I will send it....John(UK)....fergusontractors@hotmail.com |
[Reply] [No Email] | |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
