Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Oil Leak At Hand Hole.
[Return to Forum]
Justin Morgan
09-06-2012 06:24:02
50.102.76.210
Trying to put my dad's TO-20 back together after replacing the oil tube that holds the oil filter assembly together. I can not get the plate to seal back up onto the oil pan without leaking. I've put a new rubber o-ring/gasket between the plate and the pan and still get a slow drip. The Operation and Maintenance book says, "To prevent leaks due to gasket stretching, firmly shellac filter cover gasket to pan or gasket cover."
How do you "shellac" a gasket to the pan or gasket cover?
[Reply]   [No Email]
ShadetreeRet
09-08-2012 12:55:13
184.4.21.191
 Re: Oil Leak At Hand Hole. in reply to Justin Morgan, 09-06-2012 06:24:02
Hmmm, hadn't heard the term "gasket shellac" for quite sometime now. It has been pretty well replaced with gasket maker in a tube which generally works better anyway. When those tractors were built, "shellac" was about the only sealer available. It came in a can with a brush applicator made onto the cap, and before you installed the gasket, which was generally cork back then, you painted both sides with shellac. Darned stuff worked too, 'cause when you removed a gasket it required a lot of scraping to get the old stuff cleaned off.
[Reply]  [No Email]
2tractors
09-07-2012 05:58:49
207.144.5.133
That plate seems to get bumped around and deformed, coat both sides of the rubber gasket filling in all the low spots and tighten.Leave it overnite before adding oil.
[Reply]  [No Email]
Bruce(OR)
09-06-2012 16:10:47
97.115.44.108
Make sure the tube is screwed all the way into the block.
[Reply]  [No Email]
Todd Broucksou - MCNC
09-06-2012 07:28:23
128.109.139.150
I used the ultra-black silicone, had to do it twice, and it worked. Also used new copper washers on the the two bolts (drain and filter plate).
[Reply]  [No Email]
Justin Morgan
09-06-2012 06:46:29
50.102.76.210
 Re: Oil Leak At Hand Hole. in reply to Maxwell99, 09-06-2012 06:24:02
I tried "Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker" along with the rubber gasket and it still leaked. Does the Shellac work differently from the RTV?
[Reply]  [No Email]
John(UK)
09-06-2012 06:29:05
79.76.243.184
Shellac is a varnish-like "paint" that you apply and this makes the seal...John(UK)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
