Compensating Spring
CABOYSAVOR
New User
The spring on the upper arm for the throttle governor on my TO35 broke.
It is still attatched to the curved part of the assembly, but I can"t seem to see where the other end would attach.
One end is attached to the curved link and the other is attached to the Thermostat Housing. It may just have a hole in the housing where an adjuster bolt was used attached to the spring and then you need to tighten the bolt to stretch the spring slightly. If you need more help with it, email me....John(UK)[email protected]
