Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: TO30 camshaft problem
[Return to Forum]
John (AR)
08-30-2012 14:16:02
130.184.71.94
I have started evaluating a TO30 (Z129 engine)that I purchased 2 years ago and parked in the barn until I had the time to work on it. When I bought it I was able to get it to "run" and compression was OK and even, but it has obviously been neglected for a long time and the oil was black, but no water in it.
I dropped the pan and saw that the aluminum drive gear on the oil pump was pretty chewed up, so I put in a rebuilt pump. The timing gears looked a little beat up too, so I pulled the timing cover to replace them also.
Well, I found the cause of the gear wear. The camshaft gear is wobbly on the camshaft! I have not been able to remove the retaining nut to get the gear off. If I hold the gear from rotating (by keeping the crank from turning) the camshaft turns with the nut. I noticed this when the rockers started to move. So, probably the Woodruff key is sheared or dropped out, the gear is wallowed, and the end of the camshaft is worn, but I have not been able to take off the nut that retains the inside part of the governor and the camshaft timing gear to really see.
OK, so here are my questions for someone who has been here before and could suggest what might work:
1. How can I keep the camshaft from turning (from inside the crankcase) while loosening the retaining nut? Is it normal rotation thread? Would vise grips on the rough part of the camshaft be OK to keep it from turning? Any other ideas?
2. Because the engine is not inverted (still on tractor) what is a good way to keep the tappets from dropping out when I do get the cam to come out? I have read about using "pencil magnets" down the pushrod holes. Anyone have luck this way?
3. How do I keep track of the timing issues as I go along? I documented the relative position of crank, cam, distributor rotor and flywheel before I started messing things up, so I hope I can get the timing back. Oddly, the marks on the timing gears were together when piston #4 was at compression top dead center rather than piston #1 as I have read. The distributor rotor was pointed to plug wire #4. When #1 was at firing TDC the marks on the cam gear were 180o off. Does this make any difference as long as the ignition and valve timing are synchronized?
Please forgive this long thread. I wanted to give enough information so someone with experience with these engines could point me in the right direction. Thanks for taking the time to read it.
John
[Reply]   [No Email]
John (AR)
09-01-2012 16:20:05
72.204.53.48
 Re: TO30 camshaft problem in reply to John (AR), 08-30-2012 14:16:02
Hi Folks,
Thanks for the replies to my questions. The impact wrench with a vise grip pliers on the camshaft did the trick in getting the camshaft gear retaining nut off. Thank you Dick for the suggestion!
What I discovered was that the camshaft timing gear was broken concentrically around the hub of the gear, allowing the camshaft to turn separately from the body of the gear, or vice versa. The camshaft was still in good shape with the hub of the gear still firmly keyed to it. So I won"t need to replace it. Yea!
I am wondering if this was a weak part of the cam gear casting. The breakt ran through the two large access holes in the face of the gear and around the hub on the back of the gear. I could not see the problem until I removed the nut holding the back part of the governor assembly and the cam gear onto the camshaft.
I guess it was luck that I could get the tractor to run at all, so I have named her "Old Lucky". Hopefully a new camshaft gear will get her running properly.
There is still the nagging question of why the gear broke in the first place...
Anyway I hope this thread will help someone else with a similar issue.
Thanks for providing a great source of information to us Ferguson Folks.
John
[Reply]  [No Email]
JPFL
08-31-2012 05:30:37
173.65.222.172
I have a good used cam with gear for sale. I also have other Freguson parts. Thanks Jim 813---------
[Reply]  [No Email]
Dick New York
08-30-2012 21:33:27
67.255.58.21
Can you get to the nut with a impact wrench . If the cam is no good , how about grinding the head of the bolt off with a cut off tool ?
You might be able to hold the lifters with good cloths pins through the side covers .
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
