| Harry Ferguson Tractors Discussion Forum |
Topic: No Spark!
[Return to Forum]
| Author |
[Modern View]
| Thomas(AB)
08-29-2012 13:58:13
209.91.107.189
Using my TE20 to mow earlier this year, parked it after running for 3-4 hours, has refused to run since. Has no spark, replaced coil x 2, rotor, cap, all spark plug wires, points, condenser x 2- when the first one was tested it was bad. Tractor is still 6 volt, ground has been cleaned and moved by the starter, i have power to all the right places, i have power to the points,the coil, when put on another engine works, im about ready to push it into the slough. Any ideas?? Thomas |
[Reply] [No Email] | |
| phil(va)
08-30-2012 18:47:17
76.1.132.68
Re: No Spark! in reply to Thomas(AB), 08-29-2012 13:58:13
| I have had similar thing happen as Tony said. Tried the usual stuff with TO-30 that didn't have fire. Pulled one plug wire and put in spark tester, the type you buy from Northern Tool for 5 bucks, and tractor started right up. |
| miner09
08-29-2012 17:03:10
75.227.148.199
| You can put a wire straight from positive post to the coil battery side + and if it runs then you know what to look for.A broke wire or loose. If it doesn't run then you know it is in the distributor. |
| Bruce(OR)
08-29-2012 16:06:59
97.115.44.108
| Wouldn't be the first time I have seen new points that are glazed over. You might simply drag a points file over them and see what you get. |
| Tony in Mass.
08-29-2012 15:00:26
76.127.224.161
| I forgot where I posted the details a few weeks ago, but the F162 in my Cockshutt was as dead and clueless as yours. As I turned the starter, a forklift mechanic freind who is knowledgeable with Continentals, held a plug wire straight up as I cranked. He slowly lowered it to its plug, and when still several inches above it, the tractor started, running on the other 3. He got zapped of course, so I shut it off, he replaced the wire to the plug, it started perfect and has been starting fine ever since. I just had it running an hour ago... and it still defies explaination... it's free so give it a try. Good luck. |
| 2tractors
08-29-2012 15:28:41
207.144.5.133
Re: No Spark! in reply to Tony in Mass., 08-29-2012 15:00:26
| Boy I wish we had magicians around here!!While you were mesmerized with the sparkplug hand he turned on the petcock with the other. That's the oldest trick in the book. HaHa No really undo the carb bowl screw and check gas flow. Do you have a spark with the plug grounded? |
| Thomas (AB)
08-29-2012 16:19:41
68.171.231.83
Re: No Spark! in reply to 2tractors, 08-29-2012 15:28:41
| Checked the gas....got gas flow. I have no spark when the plug is grounded. Going to try dragging a file across the points. Thanks All!! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
