Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: alternator pulley for TO-30 conversion to 12v
[Return to Forum]
Charlie
08-28-2012 19:46:07
72.71.214.221
Just bought a standard kit for the 12v conversion of this tractor, but the alternator pulley isn't wide enough for the belt on my tractor. Have seen others raise this issue, but no resolution. Has anyone found a 2-1/2 inch diameter pulley that takes the 7/8 inch wide belt. The old generator pulley is larger diameter than on the kit and would probably not give high enough rpm. Need bore of .671 to fit alternator.
[Reply]   [No Email]
phil(va)
08-30-2012 18:50:45
76.1.132.68
Re: alternator pulley for TO-30 conversion to 12v in reply to Charlie, 08-28-2012 19:46:07
Pulley on the conversion kit from this site is correct size.
  [Reply]  [No Email]
Jerry/MT
08-29-2012 17:51:42
206.183.116.145
I bought the correct pulley for the 5/8" wide belt from Genesee Products (www.geneseeproducts.com)a few years ago
for under $20 and the the guy gave me the correct instructions for removing the old one and putting on the new.
  [Reply]  [No Email]
Charlie
08-29-2012 14:53:38
72.71.215.135
Follow up to previous responses in reply to Charlie, 08-28-2012 19:46:07
With respect to the idea of using a 3 wire system and the original larger generator pulley, is there a way to do this with my "1 wire alternator"? It has a rubber plug over 2 terminals that seem to be part of the regulator. Can I use them somehow to make this a 3 wire system? Or might it be possible to jsut use the system as one wire as long as I rev up the engine temporarily to energize the alternator to get it started.
  [Reply]  [No Email]
Trac
08-29-2012 16:20:13
76.6.48.186
Re: Follow up to previous responses in reply to Charlie, 08-29-2012 14:53:38
Good question i got a one wire alt. from ebay once that i could not get working came with brackets belt ever thing but could not get it to work maybe i was doing something wrong then i found out how to wire it with 3 wires and it worked. They install something that's a self exciter that's why it needs to be revved up to charge. Pull off the rubber boot & look for the two tabs if there then yes.
  [Reply]  [No Email]
Charlie
08-29-2012 18:48:43
72.71.215.135
Re: Follow up to previous responses in reply to Trac, 08-29-2012 16:20:13
I have the two tabs, but what do I do with them?
  [Reply]  [No Email]
Trac
08-30-2012 05:32:52
76.6.48.186
Re: Follow up to previous responses in reply to Charlie, 08-29-2012 18:48:43
Are the tabs marked 1 and 2? #2 tab goes to the theaded post, #1 tab goes to the key switch the post goes to the + side of the ammeter the - side goes to the key switch but now you need a 3 prong key switch one that has lights or accessory (acc.) so the alt. can be turned off if not the tractor will always run. The alternator will keep putting out power to the distributor.
  [Reply]  [No Email]
Trac
08-29-2012 13:57:42
76.6.48.186
I'm with Duner Wi i have the three wire Alt.hook up on my TE20 and i used the original pulley i have no issues with charging even at idle speeds.
  [Reply]  [No Email]
Jeremy in DE
08-29-2012 06:24:44
70.192.131.213
My 12v conversion kit came with a 5/8" pulley. I bought a 5L400W belt at Napa, and it works great. A previous owner installed an even narrow belt before I bought it; I could never keep that tight enough for effective charging, with either the generator at first or the alternator after the conversion. My experience says you don't need the full 7/8", but don't get too narrow.
  [Reply]  [No Email]
2tractors
08-29-2012 05:35:36
207.144.5.133
I had an issue with the thinner belt squeeling and put a 5/8 pulley off ebay on the alt.
  [Reply]  [No Email]
Charlie
08-29-2012 05:58:39
72.71.215.135
But my TO30 belt is 7/8 in reply to 2tractors, 08-29-2012 05:35:36
My belt is larger than most of the ones I read about, although it seems to be the correct one for the TO30. So I need much larger than a 5/8 pulley. Hard to find anywhere. Need a pulley for a 22mm belt with a 17mm bore in metric.
  [Reply]  [No Email]
Duner Wi
08-29-2012 04:49:25
216.226.80.242
I use the pulley from the generator and it works fine with 3 wire hook up.
  [Reply]  [No Email]
PackardV8
08-29-2012 03:44:49
64.12.116.66
My TE 20 has a Delco alternator instaled by former owner. He used a belt to fit the alternator pulley and yes it ran deep in the groove of the water pump and crank pulley. Seemed to work ok for the short period of time i ran it.
At this point maybe just run the narrow belt and try it. If it works then it works.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
