TractorLinks.com
Show Parts for Model:
Re: TE 20
Bruce(OR)
08-25-2012 18:50:50
I did this on a 9N. A trip to Home depot and the plumbing section will get you a copper "T" fittting to install into the upper rad hose. Your sender screws into the "T".
Ivan in Mich
08-25-2012 18:58:31
 Re: TE 20 in reply to Bruce(OR), 08-25-2012 18:50:50
What do you have to do cut the upper hose? Do you remember what size tee it is? Thanks Ivan
Richard L
08-25-2012 20:01:15
 Re: TE 20 in reply to Ivan in Mich, 08-25-2012 18:58:31
Ivan if you have a Ferguson TE 20, TO 20, TO 30 parts book look on page 12, numbers 57 and 58 those are the washer and plug that goes into the water neck where the temperature bulb is suppose to attach before you can attach it you need to get a "short" adapter so the bulb has enough room to fit in there. The size of that adapter is 5/8" NF and as short as you can find I am fairly certain. If you haven't purchased the water temp gauge try to find one that has a 48" cord on it. That is just a little longer than you need and anything longer is a waste as you will have to coil it up quite a bit more than the 48 inch one.
