Battery powder
Anonymous-0
Can anyone tell me how to get rid of the white powder that keep building up under the battery box on my tractor. I assume it's from the battery and I have tried spraying commercial produces on the battery terminals and setting the battery in rubber and putting rubber around the tie down poles. I also have smeared grease everywhere, but nothing seems to stop it. Thanks in advance.
I use just motor oil. There is a battery spray you can get at auto parts supply. White powder comes from the acid in the battery. You can clean with baking soda and water. Wet battery with water and sprinkle soda let set then wash off with water hose.Put oil around post.
