TO 20 fan belt
Bill DiLenge
New User
Looking at earlier discussions it appears you remove the crank pully to get a new fan belt on. Is that correct? My TO 20 has a loader and I've already moved the pump foreward and removed the shaft.
Thanks
I am thinking when I replaced my fan belt I loosened the generator removed the belt from that pulley and off the crank pulley then worked it around and over the fan blade then put new one on in reverse order.
Richard,
That would make sense except in my case there is a tube that extends forward from the front crank pulley to the front engine support. The pump shaft runs thru it.
Thanks
