clutch blocking
s19438
the last time i fired up my 35 the clutch was stuck. it did free itself but i think i need to block the clutch. will any harm be done if i do that?
i only run the tractor a few times a year.
thanks.
I block all of the clutch on all of my tractor if they are going to set any length of time. I have never had a problem ever.
Bob
I push my clutch pedal down and use two light weight plastic wire ties to hold it to the step plate. If I had heavier ties I am sure one would hold it. I only do this during the winter when I won't be using it for a while.
I use this , works a treat.
