Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: TE 20 12v wiring diagram
[Show Entire Topic]  [Return to Forum]
DON TX
08-23-2012 21:48:43
76.196.7.79
Wouldn't that bypass the coil? The resistor is between the coil and the dizzy. Should I jump the bat+ to coil+?
DON TX
[Reply]   [No Email]
Packardv8
08-25-2012 06:17:00
64.12.117.78
 Re: TE 20 12v wiring diagram in reply to DON TX, 08-23-2012 21:48:43
If it is ALL 6 volt then no resistor is needed. If it is 12v then look at the coil to determine if it is INTERNALLY resistor coil or not. If it is INTERNAL resisted 12v coil then no ballast resistor is needed. If a regular 12v coil (not internally resisted) then a ballast resistor is a good idea between coil and ingnition switch. If no ballast resistor is used on 12v then points life will be short.
IF weak spark then TEMPRORarily bypass (eleminate) ballast resistor and try that to see if spark improves. If spark inproves then coil mite be internally resisted AND or bad ballast resistor.
THose of u running a one wire alternator mite want to put something like a 40 AMP fuse on the wire that comes out of the alternator. If the one-wire alt suddenly kicks out a heavy dose of amperage then the wire or other wires could fry if they are not heavy enuf to handle the amperage. This could happen under situations of a very low charged battery or somekind of a short should a wire somewhere in the electrical system get pinched by brush or other conditions.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
