TractorLinks.com
Show Parts for Model:
Re: valve adj
rustred
08-23-2012 07:53:07
get #1 cyl. at tdc on compression. you do this by watching the valves on its running mate, which is #4 cyl. when one closes and the other one starts to open thats when you stop rotating the engine.#1 is on tdc on compression now. this is called valves on the rock. cause you just rock the engine a bit each way and the valves do the same. then when # 1 cyl. is set you just follow the firing order for the adjust ment. 1 3 4 2 in that order. 1 3 4 2 are the running mates for 1 and 3 cyl's * for cold adjustment you need to add a couple thou. to the hot spec. and this is the proper way to adjust valves.
