Anonymous-0
Just got this old TO20 that came with some property I bought. I can't find the reverse gear. It will shift the H pattern but I can't get it to go over to the right without lifting the stick and when I lift the stick it will only move forward to the start position. Surprisingly, it started up and ran very smooth considering it had been sitting for about a year. I think it needs some carb work since it would only run fully choked and would die when I tried to go up a hill. It had plenty of power to turn the mower in pretty thick grass though. It had milky looking oil and the radiator was about a quart low so it probably has other issues but I just need to mow a small area. It was kinda cool running this old thing, I've only used newer diesel stuff but the engine was remarkable smooth and just purred at idle.
