TractorLinks.com
Show Parts for Model:
13.6 tires on to30?
ruger1
08-20-2012 05:11:47
i found a great deal on 13.6 x 26 tires and rims, will they work on a TO30?
ruger1
08-20-2012 14:34:13
 Re: 13.6 tires on to30? in reply to ROZ, 08-20-2012 05:11:47
The rims are not loopholes, the craigslist link shows pictures of the rims/tires. All the measurements are the same regarding the studs and center cutout.
Tony in Mass.
08-20-2012 14:20:27
 Re: 13.6 tires on to30? in reply to ruger1, 08-20-2012 05:11:47
What are they from? An AC I'll bet. Well, no wheel centers that fit a fergie are going to match up with 26" rim loopholes. If you had the wheel centers with the tires and rims, I doubt that will bolt up to the fergie hub and lug studs. You can measure everything on you tractor and compare to the stuff for sale... but a fit up is unlikely...
leej
08-20-2012 13:58:57
Can't the rim be revirsed, install the tire also
reverse. Not sure but If I remembered correctly
it can be done, but measure before you buy the tires. ggp
ruger1
08-20-2012 08:34:35
[quote="Jeff-oh"](quoted from post at 15:32:43 08/20/12) The wheel center and rim are set up for a 28" tire. Are you replacing it down to the hub?
If just the tire it would not fit inside diameter is too small.[/quoteu
So these would not work? I did not plan on replacing the hub. From what i can tell the Ford 801 had 28" rims from the factory but seller had these on the tractor for a while.
http://buffalo.craigslist.org/grd/3214597860.html
This post was edited by ruger1 at 09:08:19 08/20/12.
Jeff-oh
08-20-2012 07:32:43
