| Harry Ferguson Tractors Discussion Forum |
Topic: Help with TO-30 Stalling
[Return to Forum]
| Author |
[Modern View]
| Bluegrass40505
08-13-2012 06:44:02
184.43.84.104
Thanks in advance for any insight to this problem.Here is the situation with my To-30. New cap, rotor, plugs, wires, coil,and a pertronix electronic ignition. New ignition switch and all new wiring. New gas tank, sediment bowl and fuel line. Quick to start up and runs smoothly for approximately 3-5 minutes then loses power, sputters, backfires and then quits. Checked spark....strong and bright. Gas flows hard and fast from bottom of carb. It will then not restart until it cools off a bit. Then it will happen all over again. I do notice that the exhaust manifold gets extremely hot very quickly; more than I ever recall on any tractor. Could I possibly be looking at a manifold leak or exhaust valve problem? |
| Bluegrass40505
08-19-2012 12:52:40
184.43.84.104
Re: Help with TO-30 Stalling in reply to Bluegrass40505, 08-13-2012 06:44:02
| | UPDATE: Thank you for all your advice. I had a little time this week to check out everything again. It would start on the first bump of the starter and run smoothly for anywhere from 40 seconds to 2 minutes. Then sputter, backfire, and quit. Pulled coil wire and had strong bright spark. Electronic ignition recently installed...so no condensor or points problems. Gas always flowed strong and fast from bottom of carb. Exhaust pipe removed to assure no blockage. After stalling out, I could immediately restart and purr smoothly for 30 to 90 seconds. Then repeat again. Today revealed a potential clue......water in the oil. But no oil in the radiator. Cold this be the AH-HAH! moment? Today's project was adding one can of K&W block seal. In a day or 2, I'll see how things hopefully improve. |
| Bob Mc
08-15-2012 15:05:45
75.107.0.52
| | Yesterday the exact same thing happened to my TO35. The problem was what Jerry/MT said. A 12v. 1.6 OHM coil with no external resistor,and the points were burned. New points and condenser with a 3.6 OHM 12v. coil and all is right with the world! Bob Mc |
| Jerry/MT
08-14-2012 12:42:07
206.183.116.145
| | Hot manifold is usually a result of an excessively lean mixture and /or retarded timing. Check you spark immediately when it stops running. If you have a 12V system, it could be you have a 1.6 ohm coil without a current limiting resistor. |
| s19438
08-14-2012 07:06:22
72.94.45.81
| | loses power, sputters, backfires and then quits most likely a carb problem. take carb off after you have tried everything else and check float for proper setting. a carb rebuild kit might not be a bad idea. |
| miner09
08-14-2012 05:00:01
75.222.119.207
| Check for weak coil after it's hot. |
| Bob Mc
08-13-2012 19:41:17
75.107.0.38
| | Is the gas tank vented? You might try loosening the gas cap and see if that cures the problem. Bob Mc |
| 47 Bill
08-13-2012 09:20:19
173.166.167.77
| Has tractor been sitting? I had a farmall cub with underslung exhaust that did same thing. Mud daubbers had clogged exhaust pipe. I would try unhooking exhaust pipe and see what happens. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
