Fluid capacities te 20
DON TX
Maybe I've had 1 too many. I can't locate the capacities in my shop manual or the forum here. Can someone post them? TIA
DON TX
Capacities for petrol engined TE 20
Engine 6.8 litres with filter change.
Transmission , gearbox, axle combination all filled from the gear box filler cap 23 litres.
Steering box 2.9 litres.
Front hubs , each .35 of a litre.
Air cleaner .43 of a litre.
I wont use imperial gallon measurements as they differ from US gallons and will only confuse the issue.
I'm a little confused on the replies. What are ya'll calling the gearbox? I tend to believe the 23 litres is correct since the 3 compartments are contiguous. The hyd dipstick shows it's overfilled, yet I can barely see any oil in the transmission thru the filler up hole. It looks like it's only an inch or 2 deep. It's just above the bottom ring of the big gear you see when you look in the hole. Thanks for the replies.
DON TX
(quoted from post at 08:29:20 08/11/12) I'm a little confused on the replies. What are ya'll calling the gearbox? I tend to believe the 23 litres is correct since the 3 compartments are contiguous. The hyd dipstick shows it's overfilled, yet I can barely see any oil in the transmission thru the filler up hole. It looks like it's only an inch or 2 deep. It's just above the bottom ring of the big gear you see when you look in the hole. Thanks for the replies.
DON TX
The wife's TO-20 uses 6 gallons in the gear box, (trans, Hyd pump and rear diff) Pour in 4 gallons and wait for it to go where it needs, add the 5 th gallon and then slowly add the final to the fill mark.
23 litres is correct, the oil does take some time to level out . When looking into the gearbox through the filler hole[ near stick shift] the oil does not seem to be very high even when the rear end dip stick shows full . The gear box sump seems to hold most of it . Presumably the gears fling it around when rotating.
That makes me feel better. Seems like my 8N shows more oil lookin down the filler hole, maybe my imagination. Oil on the dipstick looks good. Feller that owns it doesn't know the maintenance history so I'll run it a while before I decide if it needs changing. May be a lot of water in the bottom. Just got thru shinin up the connections and she spins like a top now. I'll put some gas in tomorrow and see if she starts up.Thanks to all.
DON TX
If mine was better I wouldn't have to ask the ?. I know I have the answer written down somewhere. (%^)
DON TX
