Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Fluid capacities te 20
DON TX
08-10-2012 20:41:46
Maybe I've had 1 too many. I can't locate the capacities in my shop manual or the forum here. Can someone post them? TIA
DON TX
Michael QLD OZ
08-12-2012 03:32:06
 Re: Fluid capacities te 20 in reply to DON TX, 08-10-2012 20:41:46
OOPs seems like the memory is less than 50% ok.
DON TX
08-12-2012 12:07:16
 Re: Fluid capacities te 20 in reply to Michael QLD OZ, 08-12-2012 03:32:06
If mine was better I wouldn't have to ask the ?. I know I have the answer written down somewhere. (%^)
DON TX
Charles in Aus.
08-11-2012 15:52:33
23 litres is correct, the oil does take some time to level out . When looking into the gearbox through the filler hole[ near stick shift] the oil does not seem to be very high even when the rear end dip stick shows full . The gear box sump seems to hold most of it . Presumably the gears fling it around when rotating.
DON TX
08-11-2012 19:59:34
 Re: Fluid capacities te 20 in reply to Charles in Aus., 08-11-2012 15:52:33
That makes me feel better. Seems like my 8N shows more oil lookin down the filler hole, maybe my imagination. Oil on the dipstick looks good. Feller that owns it doesn't know the maintenance history so I'll run it a while before I decide if it needs changing. May be a lot of water in the bottom. Just got thru shinin up the connections and she spins like a top now. I'll put some gas in tomorrow and see if she starts up.Thanks to all.
DON TX
DON TX
08-11-2012 08:29:20
I'm a little confused on the replies. What are ya'll calling the gearbox? I tend to believe the 23 litres is correct since the 3 compartments are contiguous. The hyd dipstick shows it's overfilled, yet I can barely see any oil in the transmission thru the filler up hole. It looks like it's only an inch or 2 deep. It's just above the bottom ring of the big gear you see when you look in the hole. Thanks for the replies. DON TX
Bruce(OR)
08-11-2012 11:25:06
 Re: Fluid capacities te 20 in reply to DON TX, 08-11-2012 08:29:20
The wife's TO-20 uses 6 gallons in the gear box, (trans, Hyd pump and rear diff) Pour in 4 gallons and wait for it to go where it needs, add the 5 th gallon and then slowly add the final to the fill mark.
Charles in Aus.
08-11-2012 02:53:20
Capacities for petrol engined TE 20 Engine 6.8 litres with filter change.
Transmission , gearbox, axle combination all filled from the gear box filler cap 23 litres.
Steering box 2.9 litres.
Front hubs , each .35 of a litre.
Air cleaner .43 of a litre.
I wont use imperial gallon measurements as they differ from US gallons and will only confuse the issue.
Michael QLD OZ
08-11-2012 01:29:50
From memory the engine takes 5.5 to 6 litres of 20/50 oil.
The gearbox takes 7.5 litres of the same oil
