it didn't go well
s19438
i got the tach apart; very apart that is. broke the glass and the bezel (?) is in pieces. don't much care about the bezel as it was rusted out but the glass would have good to save. soaked it with PBB and it is working.
now what to do with it ????
Cutting glass is not that hard, sharp cutter , lubricate with Kerosene, use new glass and score once only and deeply, never go back over the same cut as it creates fracture lines in different directions. A series of curved cuts hugging the outline of the circle you want to cut is easier than one circular cut. Otherwise any glazier worth their salt should be able to cut a piece for a few dollars.
