Ferguson TE-20
Put all the gears into neutral. If you cannot put all gears into neutral you probably have bent shifter fork(s)
You can disconnect the top of the steering column complete with dash from the steering box and gearbox cover , then slide the box cover out from under the dash and steering turret, looks very strange when done but saves hours of fiddling
An explanatory photograph, from 1260 Engineer
Charles.
What is the lever under the dash? Is that a hand throttle?
What is the plate attached to the right side of the dash?
Strange air cleaner inlet?
Bob
Bob , this one is a TEF , plate shows starting instructions for Kigass system, 'Lever' is some sort of bracket , nothing mechanically operational .
Bob , I am suffering brain fag from watching the Olympic games, the 'Bracket' is of course the diesel engine decompression lever !
Apologies , Charles
