Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Lift cylinder question
John (UK)
08-06-2012 05:58:15
The fact that the system is cycling like you say does not mean that there actually is a problem unless you can actually see a leak from the Lift Cylinder, it can be adjustment or wear that causes this. It is a natural reaction if the system drops, it is supposed to lift again, but it can also be caused by adjustment as well. But the deciding factor is whether there is a leak from the Lift Cylinder.When you work on hydraulics unless you are fully aware what you are doing it is often better to leave them alone, especially the Pump, taking it apart does not always reveal if there are problems, by taking it apart you can make matters worse. You should always find out the location of the problem first and repair the fault, then re-test the pressure again to see if all is OK. Sometimes when this happens it means that you need to re-assemble the system and then do the tests that should have been done originally so that you can repair it. Take the r/h side cover off and operate the lever, if there is oil leaking as before from the back end of the lift cylinder, then really you only have one option and that is to replace it. A leak anywhere on the system will cause the problem you have, as it is just a pressure loss.
Take off the L/h cover and check the high pressure pipe in the front right corner when it is under pressure (try to lift a 2 bottom plow)as these can split due to shock loads in transport. If there is no real amount of oil leaking on the Cylinder then you should adjust the Control Lever Quadrant to the correct setting..John(UK).fergusontractors@hotmil.com
