Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Hangs in gear constantly.
john(UK)
08-05-2012 05:46:27
First thing to do is check the amount of free-play in the pedal, it should be no more than 3/8" measured under the footrest to the top of the Pedal arm.Check it when the tractor is HOT. If this is correct than the Clutch is dragging, possibly because of some oil on the plate. If you remove the Starter you will see if there is any oil inside as it will be on the Pinion of the Starter. make sure the weep holes underneath are clear. If you have recently re-filled the transmission then you may have poured too much into the transmission at any one time. You should add 2 gallons then wait 15 mins before adding any more. If it overfills the transmission it can leak trough a worn seal on the drive shaft. It can also be wear in the Clutch itself and it isn't opening the clutch evenly and that would also cause drag on the plate....John(UK)....fergusontractors@hotmail.com
