TractorLinks.com
Show Parts for Model:
Need PTO seal part number
Ron J.
08-04-2012 15:16:19
Hi. I'm replacing the PTO seal on my Fergy TO-30. I removed the old seal, but there was no visable part number on it. Can anyone help me out with a replacement seal number? Thanks, RJ.
john(UK)
08-05-2012 05:19:01
 Re: Need PTO seal part number in reply to Ron J., 08-04-2012 15:16:19
The oil seal can be purchased locally from anyone who sells oil seals. The size is:-
1-5/8" x 2-1/2" x 7/8", the seal they will often give you is narrower than this but this seal need a seal protector on it then it wont get damaged by grass etc wrapping around it. This protector is usually made of leather, but it could be made of something else now. The narrower seal is no use for this purpose or you will be replacing it again quite soon. You should check the collar on the PTO shaft that the lip of the seal rubs against. If it is marked at all, in any way, it will damage the seal lip and it should be replaced.Use some grease on this collar when you slide the seal onto it. When you refill with oil, use Multi-grade 10W/30 which is a lot better than the original oil that was specified...John(UK)....fergusontractors @ hotmail.com
Ron J.
08-13-2012 19:21:41
 Re: Need PTO seal part number in reply to john(UK), 08-05-2012 05:19:01
Thank you very much for the great information. RJ.
Bruce(OR)
08-04-2012 16:05:27
Your local Case dealer can help you with no problems. This site also has your part.
Ron J.
08-13-2012 19:24:05
 Re: Need PTO seal part number in reply to Bruce(OR), 08-04-2012 16:05:27
Thanks Bruce, I found it on this site after I posted. I appreciate it. RJ.
Richard L
08-04-2012 16:34:07
New Holland dealer will probably have it also especially if they used to be a ford dealer. According to this site the original number was 195763M1 the dimensions are 2.45 OD, 1-5/8 ID and 5/8" wide.
Ron J.
08-13-2012 19:28:23
 Re: Need PTO seal part number in reply to Richard L, 08-04-2012 16:34:07
Thank you Richard, I found it on this site after I posted, and used the dimensions and part number to order it from my bearing supplier I appreciate it. RJ
