TractorLinks.com
Show Parts for Model:
Ferguson TE-20
Jerry Vanderbeek
08-04-2012 15:08:24
I did take off the shifter and cover and tryed to pry into 1st or 2nd.Some is stopping it from doing so!
Charles in Aus.
08-06-2012 14:43:15
 Re: Ferguson TE-20 in reply to Jerry Vanderbeek, 08-04-2012 15:08:24
Bob , I am suffering brain fag from watching the Olympic games, the 'Bracket' is of course the diesel engine decompression lever !
Apologies , Charles
Charles in Aus.
08-05-2012 14:54:56
Bob , this one is a TEF , plate shows starting instructions for Kigass system, 'Lever' is some sort of bracket , nothing mechanically operational .
Bob (Aust)
08-05-2012 12:44:54
Charles.
What is the lever under the dash? Is that a hand throttle?
What is the plate attached to the right side of the dash?
Strange air cleaner inlet?
Bob
Charles in Aus.
08-05-2012 02:40:49
An explanatory photograph, from 1260 Engineer
Jerry Vanderbeek
08-05-2012 03:02:55
 Re: Ferguson TE-20 in reply to Charles in Aus., 08-05-2012 02:40:49
Thank you Sir Charlies.You've been a big help!
Charles in Aus.
08-05-2012 02:27:09
You can disconnect the top of the steering column complete with dash from the steering box and gearbox cover , then slide the box cover out from under the dash and steering turret, looks very strange when done but saves hours of fiddling
Bruce(OR)
08-04-2012 16:03:52
Put all the gears into neutral. If you cannot put all gears into neutral you probably have bent shifter fork(s)
Charles in Aus.
08-04-2012 15:17:45
You can take the gearbox cover off without removing the dash board, this may simplify the job a little
Jerry Vanderbeek
08-04-2012 15:30:07
 Re: Ferguson TE-20 in reply to Charles in Aus., 08-04-2012 15:17:45
The gear box cover is connected to the steering colum.
