Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Ferguson
Jerry Vanderbeek
08-03-2012 09:29:37
I have a 1951 ferguson model TO-20.Im having shifting problems.The only gear I can gear is 2ND and it will start with shifter not in the S position.PLease help if you can.Also if you have an idea of the problem could I fix it my self.I have worked on many tractors in the past,but they were much newer and not Ferugsons.Thank you very much for your time.Jerry
Richard L
08-03-2012 10:13:22
 Re: Ferguson in reply to Jerry Vanderbeek, 08-03-2012 09:29:37
If you are saying your shifter is stuck in 2nd gear remove the oil fill cap on the shifter cover and using a long screw driver reach in there and try to slide the sliders so everything is lined back up in the neutral row. Once you get them lined up you should learn not to lift up on the shifter when changing gears as this is usually what causes the gears to get locked. When the shifter unit was new it did not have the slop that it now does so it (usually) couldn't get locked in gear when new.
