Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: High-Altitude Engine
[Return to Forum]
miner09
07-30-2012 10:38:30
75.223.214.127
What is the difference of a Gas engine and a High- Altitude Gas engine? Is it only the piston's?
[Reply]   [No Email]
Indiana Ken
07-30-2012 18:42:01
66.249.232.45
 Re: High-Altitude Engine in reply to miner09, 07-30-2012 10:38:30
Typically an engine used at higher altitude can use a higher compression ratio without requiring a higher octane fuel. The higher compression helps in part to make up for the power reduction due to the less dense air. The typical way to get the increased compression is with higher dome pistons. Since the air is less dense the carburetor will need to be adjusted leaner.
If the tractor is used at sea level it will have more power than the same tractor with standard pistons however, you will need to insure the fuel has adequate octane for use with the higher compression and dense sea level air. In addition the carburetor will need to be adjusted richer for the dense air.
[Reply]  [No Email]
4on-the-floor
07-30-2012 18:29:20
173.84.219.182
 Re: High-Altitude Engine in reply to Maxwell99, 07-30-2012 10:38:30
My TO-35 is a SHM serial no. 197273 , with the ZB-134 continental gas engine. I was told by a tractor rebuilder shop that at one time they had an overhaul kit with a different piston , but if he did mine he would have to use the other kit.
Mine says to operate at 5000 ft. , i'm at 2500 ft. and it has lot's of power compared to my brothers TO-35 with the other 134 engine. That's all I have been able to find out about them.
[Reply]  [No Email]
miner09
07-30-2012 16:19:44
75.223.121.170
Years ago we Deer Hunted in Utah and use Honda 4 Wheelers and being from Texas we had to change the Jets in carburetor before it would run right in High-Altitude. I thought this might be a different jetted carburetor.I was told that the tractors used high compression pistons for High- Altitude. Propane engine takes a different piston. I never see overhaul kits that state any difference. I will know when I rebuild.
[Reply]  [No Email]
Two Dogs
07-30-2012 12:45:43
173.19.160.83
I have an FE 35 Standard gas with the SHF prefix and I'm at about 300 feet above sea level. If it ran any better I couldn't hold it. :) TDF
[Reply]  [No Email]
Richard L
07-30-2012 12:25:58
66.227.231.26
I checked in the archives and I noticed a post by John (UK) if that engine was used below 4000 ft above sea level the engine could be hurt. Then there were other posts by others that said with todays higher octane fuels it shouldn't be any problem. That was only two that I checked. There are a lot more posts to read.
[Reply]  [No Email]
s19438
07-30-2012 11:23:40
72.94.45.81
about 5000 feet. sorry.
[Reply]  [No Email]
2tractors
07-30-2012 15:06:23
207.144.5.133
 Re: High-Altitude Engine in reply to s19438, 07-30-2012 11:23:40
My fe35 gas is also a SHM. I know I'm not at high altitude but it sure ran good, had good oil pressure and no smoke. The plug reading may have been a little rich and the compression was around 140.I thought the only difference was the jetting.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
