Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Help figuring out if tractor is a 20 or 30...asap
[Show Entire Topic]  [Return to Forum]
Dan S (NY)
07-27-2012 09:21:02
216.27.112.8
Based on the serial number you have a 1948 TE20. For replacing the manifold, the type of engine is more important. TE20, TO20, and TO30s with the Continental Z120/129 engines use the same manifold. The Standard engine used in the later TEA20s used a different manifold.
Dan
[Reply]   [No Email]
GracieHope
07-27-2012 10:14:08
68.209.175.103
 Re: Help figuring out if tractor is a 20 or 30...asap in reply to Dan S (NY), 07-27-2012 09:21:02
Hello Dan
Thank you so much for this information. Is there an easy way to find out the type of engine? Is it written somewhere we can find it? If you know this it would be so helpful and thank you for your help. Have a great day!!
[Reply]  [No Email]
Dan S (NY)
07-27-2012 12:51:54
216.27.112.8
 Re: Help figuring out if tractor is a 20 or 30...asap in reply to GracieHope, 07-27-2012 10:14:08
Jerry has the engine ID facts for you. If you do have the Continental engine, there are two types of new manifolds available. The most commonly found (and cheaper) is the type used on Ferguson 35s with the Z134 Continental engine but they work fine on the older TE20/TO20/TO30 Fergusons. They look different but the only main functional difference is where the exhaust pipe attaches to the manifold. The original manifold has a beveled flange and clamp where the pipe attached, whereas the later/replacemnt manifold and pipe has a three bolt flange with a gasket. Many times the new manifold will come with an adapter to allow use of the older style pipe connection. If you need a new muffler pipe assembly anyway and you get the newer style replacement manifold you can buy a Ferguson TO 35 muffler which will bolt up directly to the new style manifold and eliminate the need for the adapter.
There is also a new replacement manifold that looks like the older style manifolds if originality is important to you. They tend to cost a bit more however.
Dan
[Reply]  [No Email]
Jerry/MT
07-27-2012 10:22:52
206.183.116.145
The continenatla engines ghave a data plate on the left side of the block at the block to cylinder head split line about midway back from the radiator The Standard engine uses in the TEA-20 has an oil filter on the left side of the block while the Continental Z120(used in the TE-20) has an internal filter in the oil pan. The Z129 Continental(TO-30) has an external oil filter on the right side of the block near the back.
Since your serial number has the TE prefix, I believe it"s a TE-20 with the Continental Z120 engine.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
