TractorLinks.com
Show Parts for Model:
To-30 broken pto shaft
Dan Heg
07-24-2012 09:06:45
I gave my friend my old brush hog which he put on his to-30...not realising the blade hit the sides when it started.....result...broken pto shaft...located a used shaft... iwas wondering how hard a job it is for a novice to replace this shaft....thanks...Dan
Dan Heg
07-26-2012 14:30:03
 Re: To-30 broken pto shaft in reply to Dan Heg, 07-24-2012 09:06:45
thanks guys...ill pass it on to him....mite hav to go his way next time i go upstate...also told him to get bearings in case they need to be replaced...the shaft broke outside the housing...a good thing im told
Jerry/MT
07-24-2012 10:16:00
It depends on how the shaft broke. Hopefully the shaft didn"t twist in the pump because then it will have to be cut off in the hydraulic compartment and removed. If it broke off at the outer end and didn"t twist the shft before it broke, it should be an easy fix.
Tony in Mass.
07-24-2012 09:59:57
The shaft is an easy job. A few minutes with a couple wrenches. Whatever sort of dent or stove in steel caused the shaft to break will be the hard job. The better brands have a slip clutch between the pto and the gearbox to avoid this expense. Best to turn the whole hog on its side and turn the blade slowly and bring the sides to as close to the original square edges as possibleToo big or small a gap is how the wrong stuff does damage if you don't see it in time.
Dukir
07-24-2012 15:03:02
 Re: To-30 broken pto shaft in reply to Tony in Mass., 07-24-2012 09:59:57
My B'Hog does not have a slip clutch. Maybe I've been lucky. How would I size and select a slip clutch for a TO30?
Jerry/MT
07-25-2012 14:38:57
 Re: To-30 broken pto shaft in reply to Dukir, 07-24-2012 15:03:02
It"s sized by pto HP.
