Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: TO-35 - Want to Add Rear Hydraulic Outlets
[Return to Forum]
SugarTractor
07-18-2012 10:07:40
24.229.44.131
I want to add external rear outlet(s) hydraulics onto my TO-35 to operate a push-pull RAM I'm having put on my 1Row McCormick PTO Potato Harvester. I would like to do this simply and as cost effective as possible. The main thrust is for the RAM to "pull-up" the diggers head out of the ground and keep it up, if it can equalize and hold the down depth when I want to dig.
Can anyone enlighten me as to what and where on the tractor I need to do what, and all that is needed, or what I might do...?
Thanks.
-WaltZ
IHartHarvest@gmail.com
http://IHartHarvest.dyndns.org
This post was edited by SugarTractor at 03:17:33 07/19/12.
[Reply]   [No Email]
SugarTractor
07-20-2012 12:21:00
72.78.2.126
 Re: TO-35 - Want to Add Rear Hydraulic Outlets in reply to Michael QLD OZ, 07-18-2012 10:07:40
Will and or any of these do:
1. http://www.ebay.com/itm/FERGUSON-FE35-F40-TO35-MH50-HYDRAULIC-SELECTOR-DIVERTER-VALVE-180908M1-60032-/150852094967?pt=LH_DefaultDomain_0&hash=item231f7c4bf7
2. http://www.ebay.com/itm/MASSEY-FERGUSON-TRACTOR-DUAL-REMOTE-HYDRAULIC-VALVE-35-135-50-135-150-165-TO35-/360423809537?pt=LH_DefaultDomain_0&hash=item53eaeee201
3. http://www.ebay.com/itm/New-Massey-Ferguson-Auxiliary-Hydraulic-Add-On-Kit-/180930252475?pt=LH_DefaultDomain_0&hash=item2a20488ebb
4. http://www.ebay.com/itm/MF738KT-Massey-Ferguson-HYDRAULIC-VALVE-KIT-35-50-65-135-165-253-261-270-285-390-/380454738400?pt=LH_DefaultDomain_0&hash=item5894de99e0
5. http://www.ebay.com/itm/Massey-Ferguson-Hydraulic-Monoblock-Spool-Valve-Sae-Orb-/380356970768?pt=LH_DefaultDomain_0&hash=item588f0ac910
6. http://www.ebay.com/itm/MASSEY-FERGUSON-HYDRAULIC-SELECTOR-VALVE-3-WAY-/130391237237?pt=LH_DefaultDomain_2&hash=item1e5bec6275
I already have a 1 arm, double acting, extend-contract, hose at each end of, RAM.
This post was edited by SugarTractor at 12:43:56 07/20/12 7 times.
[Reply]  [No Email]
john(UK)
07-20-2012 12:07:55
79.76.255.140
 Re: TO-35 - Want to Add Rear Hydraulic Outlets in reply to SugarTractor, 07-18-2012 10:07:40
To do this you are better using a Spool Valve for each of the Rams, it can be done using a change over valve but that makes it unnecessarily complicated for the operator. There are plenty of oil pressure ports and there is an oil return under the seat. If you use a Spool Valve, this fits onto the front right corner of the Top Cover. The spool valve will feed and return through this points.Only with a Spool Valve can you do what you wish in this case, successfully and easily.If you do it any other way there is a possibility that because there is no neutral on the Lever and if you forget to shut off the hydraulic power you will be constantly blowing the Safety Valve which will wear and reduce your operating pressure.Only a Spool Valve will do this easily. MF used one on their Potato Harvester and some loaders. If you can't get hold of a genuine Massey-Ferguson Spool Valve, look for one from a Loader, just make sure that you get the correct configuration of the Spools. If you have double acting Rams then you need a double acting Spool valve. Some loader valves have one of each in the Valve Block, some are both double acting. You cant use a single acting Valve with a double acting ram or vice-versa. A rough guide to know what is what with these Valves is look for how many pipe connections are on top of each Spool (that is what the the Lever operates inside) if there are two then it should be right for your purpose. One connection to each connection on the Ram. If it only has one connection on the Spool then it will only operate a single acting Ram,i.e. one way under power and the other way returns under gravity. I can send you the pictures that show you where to connect and return the oil, do not use the oil filler for this as you will over-fill the transmission and it will get into the Clutch. It must return to the correct place. I can send you the correct drawing for the pipework when you tell me exactly what you are using for the Rams and the valve If you can get hold of the genuine MF type, all this is simplified for you and will fit easily. Let me know if you need anymore info on this and I will send it, email me at the address below..John(UK)..fergusontractors@hotmail.com
[Reply]  [No Email]
Bruce(OR)
07-18-2012 22:12:43
97.115.41.3
Shoot me an email
brucewellis@aol.com
I should be able to locate you a set of plans for your "Hearts Desire".
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
