Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: TO-20 Pivot Pin and Bushing Questions.
07-16-2012 19:11:33
What we"ve got here is failure to communicate.
Typically your pin wears through the bushing and adversely wears on the axle pivot. This action mandates repair of the axle center section. Typically a machine shop operation with about $100/150 out of your pocket. When I did mine, I believe I had both bushings in possesion and requested the thicker one installed with the reasaoning it would take longer to wear through in the future.
Now once your out the cost of repair you will notice your axle has this wonderful hole in the center axle section and you will be greatly tempted to drill through the new bushing and add a grease zerk.
Grease attracts dirt and this will wear out your new bushing faster than the 50 years it took to wear out the original bushing.
Kevin Little
07-17-2012 06:56:57
 Re: TO-20 Pivot Pin and Bushing Questions. in reply to Bruce(OR), 07-16-2012 19:11:33
Thanks Bruce. Once I get it apart, I'll see what we have to work with. I have a guy up the road with a complete machine shop in his basement, so if it needs the repair, I should be OK. Do they drill it out and then sleeve it or is it better to just bite the bullet and replace the axle as a whole?
07-21-2012 07:14:08
 Re: TO-20 Pivot Pin and Bushing Questions. in reply to Kevin Little, 07-17-2012 06:56:57
Hmm. . .
Replace axle with Chinese pourous weak iron or keep high grade iron from back in the day. . .
Hmm. Let me think on that.
Might cost a penny or two to keep the high grade iron but high grade iron probably won't have catastrophic break in the future, such as a potentially weaker Chinese pourous iron copy would.
Hmm. . .
Still thinking.
What do you think?
Kevin Little
07-22-2012 18:46:46
 Re: TO-20 Pivot Pin and Bushing Questions. in reply to Bruce(OR), 07-21-2012 07:14:08
Actually, I was thinking about replacing it with an original if I had to. Trying to use all original parts. I was just wondering about the process to restore the bore.
